OK to put a via on a pad?
Discussion in 'General Electronics Chat' started by tom66, Aug 26, 2010.
  1. tom66
    Thread Starter Senior Member
    May 9, 2009
    2,613
    214
    I'm still a novice at designing PCBs, having only designed a few before. Does anyone know if it's OK to put a via on the pad of a surface mount chip, to move from layer 1 to component layer or vice-versa?
    I'm going to be using traditional PCB manufacturing houses to make these PCBs.
    Any input appreciated!
  2. Ghar
    Mar 8, 2010
    655
    72
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    No its not a good idea.. nor recommended. Simply put a really short trace and the via there.. but I wouldn't put a via one a pad that will be under the components pin.
    tom66 likes this.
  4. Ghar
    Mar 8, 2010
    655
    72
    tom66 likes this.
