Ohms law??
Discussion in 'Homework Help' started by Hotfingers, Mar 29, 2015.
  1. Hotfingers
    Mar 29, 2015
    Hi I'm new to this site and would be grateful for a bit help with some home work exam to follow shortly...if I have the resistance and the csa how do I work out the length?... Thanks guys
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What is the csa?
  3. Treeman
    Member
    May 22, 2014
    158
    15
    Cross sectional area PB. I guess we talkin wire diameters. My answer would be find the equations that use these known measurements and substitute where required.
    R=(resistivity x length) / csa
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
  5. WBahn
    Mar 31, 2012
    18,089
    4,917
    So to use that equation you need three of the four parameters. You apparently only have two. You also need to know the resistivity. Doesn't it make sense that the length of aluminum wire is going to different than length of copper or the length of steel?
    @Hotfingers : Do you have either the resistivity or at least the material that the wire is made out of?
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I missed the part about aluminum. Where did that come from?
    Nevermind, it was just an example to show different materials have different resitivity.
  7. Treeman
    Member
    May 22, 2014
    158
    15
    Treeman was being helpful as much as he could. I assumed there was more info to reveal - this seems to be the case often.
  8. WBahn
    Mar 31, 2012
    18,089
    4,917
    No problem there. I didn't realize until after I had posted that the two quotes in my response were from different people, so I went back and added the note to the TS.
    Treeman likes this.
  9. Hotfingers
    Mar 29, 2015
    Thanks for reply,s guys will continue with the homework,cheers
