OHM's Law Quiz
Discussion in 'General Electronics Chat' started by T.Jackson, Nov 22, 2011.
Thread Status:
Not open for further replies.
  1. T.Jackson
    Nov 22, 2011
    328
    14
    :: OHM's Law Quiz ::
    You any good with OHM's law?,then here's a quiz for you ...
    Requirements:
    • 6 resistors ...
    • 5 specific Vrefs of: 1, 2.2, 3, 3.3, and 4.5VDC
    • IT = 20mA
    • Calculate value of R1 - R6
    Code ( (Unknown Language)):
    1.
    2. [FONT=Courier New]              4.5V      3.3V      3V        2.2V      1V
    3.                |         |         |         |         |
    4.   5V o--/\/\/--+--/\/\/--+--/\/\/--+--/\/\/--+--/\/\/--+--/\/\/--o GND
    5.           R1        R2        R3        R4        R5        R6[/FONT]
    6.
    Show all workings, natural voltages measurable from ground.
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    This should be in the homework section.
    The OP should not in any case expect to be given a worked answer to this problem.
  3. T.Jackson
    Nov 22, 2011
    328
    14
    Thanks for that.
  4. T.Jackson
    Nov 22, 2011
    328
    14
    LOL this is a test to see everyone's general knowledge. This is trade level Ohm's law which I passed years ago.
  5. T.Jackson
    Nov 22, 2011
    328
    14
    @SGT
    Do you feel that this is a good alround test? I feel that if they can answer this, then they sort of know what they're doing.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's an OK mini-pop-quiz. It would be more challenging if it had series-parallel circuits to solve.
  7. T.Jackson
    Nov 22, 2011
    328
    14
    You ever used a PC program called DC challenge?
  8. T.Jackson
    Nov 22, 2011
    328
    14
    That got very, very hard. I beat the thing in the end though.
    Thing is, in mind it makes no sense that we are all talking about transistors and OP AMPs when we haven't a clue about ohm's law, which forms the entire basis for electronics.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    No, I've never heard of a program called "DC Challenge".
    I was formally introduced to Ohm's Law about, oh, 37 or so years ago, but I'd been using it well before then.
    There are a number of E-books available by clicking the links at the top of every page on the site; that's where much of the basics are covered.
    If you want a bit more in-depth, you could go through the Navy NEETS training series; downloadable for free in .pdf format here:
    http://www.phy.davidson.edu/instrumentation/NEETS.htm
    I went through a predecessor of NEETS back in the 70's.
    I more often than not run through the math behind a circuit if I'm helping someone - just so they'll see how I arrived at the values that I did.
  10. T.Jackson
    Nov 22, 2011
    328
    14
    Do me a favour and solve that quiz? You seem faster than me.
    There are a few ways to do it, but simply v / i won't cut it as two people have suggested.
    I should have given the hint of RT
  11. MMcLaren
    Feb 14, 2010
    759
    116
    Why not?
    1.
    2. [FONT=Courier New]    5.0V      4.5V      3.3V      3V        2.2V      1.0V      0.0V
    3.      |         |         |         |         |         |         |
    4.      | V1=0.5v | V2=1.2v | V3=0.3v | V4=0.8v | V5=1.2v | V6=1.0v |
    5.      |         |         |         |         |         |         |
    6. 5V   o--/\/\/--+--/\/\/--+--/\/\/--+--/\/\/--+--/\/\/--+--/\/\/--o GND
    7.           R1        R2        R3        R4        R5        R6
    8.
    9. I1 = I2 = I3 = I4 = I5 = I6 = 20ma
    10.
    11. R1 = V1/I1 = 0.5/0.02 = 25[/FONT]Ω
    12. [FONT=Courier New]R2 = V2/I2 = 1.2/0.02 =
    13. R3 = V3/I3 = 0.3/0.02 =
    14. R4 = V4/I4 = 0.8/0.02 =
    15. R5 = V5/I5 = 1.2/0.02 =
    16. R6 = V6/I6 = 1.0/0.02 = [/FONT]
    17.
    18.
    19.
  12. MrChips
    Oct 2, 2009
    12,624
    3,451
    I don't quite see the difficulty. I must be missing something.
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    I'm not sure, either. Maybe it's for people new to Ohms law?
    I was expecting a 10x10 grid of Resistors, with 10V on one corner, and Gnd on the opposite corner, and asked to find the voltage at point x,y in the grid.
  14. wayneh
    Sep 9, 2010
    12,374
    3,226
    Hardly. Tell me how Ohm's law explains the output from my experimental alternator, versus RPM and applied load. Ohm's law is mute on inductance and a host of other "electronics" issues. Important? Yes. But I think Maxwell and others would beg to differ on the omnipotence of Ohm's law.
    It is interesting that the historical importance of Ohm's law was in describing how voltage dropped in proportion to resistance. Other hypotheses at the time were that resistance to some power gave the right answer. Ohm suggested the power was exactly 1, and appears to have been correct, although at the time he was ridiculed for a "web of naked fancies".
  15. CDRIVE
    Jul 1, 2008
    2,223
    99
    This is an odd topic. Unless I'm misinterpreting your intentions, it would appear that your quizzing the membership to determine our qualifications. After all, you're post is more of a statement than a question.
  16. justtrying
    Mar 9, 2011
    329
    396
    what's the problem with I/R? seems to be straight forward enough.
    Pretty sure I agree with MMcLaren in terms of the answer. I got a much more difficult test tomorrow so don't need any seeds of doubt about my competency with Ohm's Law :cool:
  17. thatoneguy
    Feb 19, 2009
    6,357
    718
    I think it is having the opposite effect. ;)
  18. strantor
    Oct 3, 2010
    4,302
    1,989
    who is we? the forum members or some people in your class?
  19. thatoneguy
    Feb 19, 2009
    6,357
    718
    Did you know you can still use a calculator with a "9" button that doesn't work?
    Here's all you need to do whenever you need a 9:
    8-e^{i\pi}
    AcousticBruce likes this.
  20. justtrying
    Mar 9, 2011
    329
    396
    fancy, i would just go 8+1^0 ' cause then I don't need to enter into the complex mode. Now all I need is to figure out how to get crumbs from under my "k"...
Thread Status:
