ohms law help
Gregfox
Joined Jul 23, 2011
16
I'm trying to determine what resistor I would have to use to get 500mV from a 3 Volt
Supply.
E=IR requires a current, so I don’t know how to calculate for the resistance. I would like to know the methodology used.
Thanks!
wayneh
Joined Sep 9, 2010
17,496
You DO know the current, since it is the 3V voltage drop divided by the total resistance. Well OK, you will know it once you work out the algebra.
WBahn
Joined Mar 31, 2012
29,979
Pick a current that is reasonable, such 0.1mA or 1mA, and find the total resistance you need. The figure out how much of it needs to be in the pot to drop 1V across it. That will put 500mV as the midpoint of the pot's range.
tubeguy
Joined Nov 3, 2012
1,157
For a voltage divider to feed an op-amp input something like 1 ma current is typically OK. (This can vary depending on the op-amp used).
EDIT: I should probably look before I Post eh... :rolleyes:
WBahn
Joined Mar 31, 2012
29,979
You were probably already typing your response when I posted mine. Happens pretty frequently. I've had times when I've taken ten or twenty minutes to put a response together and after posting it find that there are four or five posts and mine is now just a repeat of stuff that wasn't there when I started responding. Oh well. If nothing else it reinforces the point being made and serves as an indicator that there is at least some agreement between responders.
Gregfox
Joined Jul 23, 2011
16
Thank you all. From what was posted I guess I have to guess the current, then work out the R value. I was hoping there was a more scientific way of doing that.
I guess I could measure the input current and go from there.
Regards.
WBahn
Joined Mar 31, 2012
29,979
It's not that you are "guessing" anything. You are CHOOSING a current level through the voltage divider.
It's like if I come up to you and tell you to find two numbers, x and y, that add to 100. Well, you can pick 50 and 50, 0 and 100, 10 and 90, -1000 and 1100, 33.33 and 66.67. All of those are equally correct. There is no "science" to it. You are given one constraint and two unknowns, so you get to pick one of the unknowns as you see fit.
In the case of a voltage divider, the desired voltage division ratio sets the ratio of the resistors, but you can multiply both resistor values by whatever constant you want as long as you use the same constant for both. That constant will dictate the total current flowing in the divider chain. Under ideal conditions, the choice is completely arbitrary and you could choose 100A or you could choose 100pA. But as you start allowing for non-ideal realities, both of those bounds get moved in. The current-delivering capability of the supply and the power dissipation considerations bring down the upper limit and the noise considerations and op-amp input bias current requirements bring up the lower end. But you will still be left with a range of two or three orders of magnitude where you can operate and be fine. You generally go for a current that is in the lower portion of that range.
With experience you will get a feel for what reasonable values to use are when you have arbitrary choices that have to be made.
30,720
There is an infinite number of solutions. The values of R9 and R10 are interdependent. We say the answer is ratiometric.
The ratio of R10/(R9 + R10) must be the same ratio as 0.5/3, i.e. 1/6.
Choose a value for R10 and R9 must be 5 times R10.
