ohms law help
Discussion in 'General Electronics Chat' started by beckyj43, May 10, 2005.
  1. beckyj43
    May 10, 2005
    could someone please help with this question?
    Assume a device draws 50 mA of current and a 150 vdc across it . what is the resistance?
  2. Erin G.
    Mar 3, 2005
    167
    Resistance = Voltage / Current
    R = E/I
    R = 150 / .05
    R = ???
  3. Brandon
    Dec 14, 2004
    306
    V=IR
    The Voltage drop across 2 points of measure = The current flowing between the 2 points times the resistance between those 2 points.
    plug n solve.
  4. n9xv
    Jan 18, 2005
    329
    Voltage = Current X Resistance
    Current = Voltage / Resistance
    With any two known quantities, you can find the remaining third quantity.
  5. legac
    May 4, 2005
    54
    Hi
    I think the term INTERNAL RESISTANCE of the DEVICE is more precise. For a circuit we use the term IMPEDANCE.
    Cheers
    Legac
  6. pebe
    Oct 11, 2004
    628
    No, the term *resistance* of the device is correct.
    *Impedance* is the resistance of a device or circuit to the flow of AC.
  7. Brandon
    Dec 14, 2004
    306
    Heh, got to get in on this.
    Actually, isn't impedance the combined Resistance (real) + Reactance (img) of a component?
  8. pebe
    Oct 11, 2004
    628
    Yes. I was going to say "Impedance is the *effective* resistance..." implying it could loosely be called that. But changed my mind.
    Wish I had left it in now :)
  9. susi
    Jun 4, 2004
    31
    ^man its so easy...just have tofind the resistance by Ohm's Law
    Data:
    Current=I=5mA => 0.05Amp
    Voltage=V=150vdc
    Resistance=R=??
    Solution:
    By using Ohm's Law:
    V=IR
    R=V/I
    R=150/0.05=3000 Ω ------Answer/
    [I hope I solved it right..lol..check the conversion of mA into Amp]
  10. pebe
    Oct 11, 2004
    628
    5mA is 0.005A
  11. susi
    Jun 4, 2004
    31
    ^lol yeh sorry its milli amp :huh:
  12. zhi_yi
    May 15, 2005
    9
    i hope i can explain something to you :) ohm law --> V = I.R
    V = Voltage, I = Current, and R = Resistance.
    if the resistance is high, and the voltage is constant. so the current will be small, and if the resistance is small, voltage constant, the current will be high.
    for example, there is some water inside a bucket, so, the sum of water is current, and the pressure is voltage, and if there is many holes under the bucket, it is the resistance, if the holes present is big, the resistance against the current will be small, so amount of water will be flow out from the bottom of the bucket, so the current on the circuit will be high, and if the holes is small, the resistance against the current will be high, so I = V/R <-- if the resistance is high, the current on that circuit will be low, for example, a battery present 1.5 volt, if we use it to a load for t times, the current will be wasted (the water inside the bucket will be flow out and the bucket will be empty), the voltage and current have linearity, if the current increase, the voltage will be increased too, V=I.R, the current will flow if the circuit is closed loop, if it's open loop, no current will flow. the current always flow to the lower path of the resistance.
    sorry, my english is broken, hope you can understand what i said >_<
  13. sellb
    May 15, 2005
