ohmmeter testing
Discussion in 'General Electronics Chat' started by gjo, Jun 8, 2013.
  1. gjo
    May 22, 2013
    28
    In my book it says "use an ohmmeter for testing for open and shorted(internally and externally) field coils. What do they mean by internally and externally?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Coil could be internally short (between the winding ) or some other externally component connect across the coli can also short the coil.
  3. gjo
    May 22, 2013
    28
    Got it, thanks
  4. studiot
    Nov 9, 2007
    5,005
    515
    Ohmeters are not very good for checking wound components, apart from continuity and insulation resistance/shorting to case, because the wire has low resistance.
    A simple tester for shorted turns can be made that works on the principle that the impedance is reduced when turns are shorted. This loads down an oscillator reducing its action.
  5. #12
    Nov 30, 2010
    16,671
    7,319
    An external short might be some electrical continuity from the coil to the mechanical case of the machine.
  6. Gdrumm
    Distinguished Member
    Aug 29, 2008
    684
    36
    Studiot,
    Can you explain the simple tester you described in more detail?
    Is it something one might build for a hobby shop?
    I work on scrapped things often, and the tester sounds like a timesaver.
    Thanks,
    Gary
  7. studiot
    Nov 9, 2007
    5,005
    515
    A simple Colpitts oscillator can be constructed from two capacitors and any old coil that is lying around.
    Activity is monitored by a high z voltmeter or transistor boosted analog milliammeter.
    PM me with an email that can receive attachments for more.
