off the shelf Relay or project ?
Discussion in 'General Electronics Chat' started by ob2s, Mar 18, 2009.
  1. ob2s
    Mar 18, 2009
    I need a 12 volt relay that has a momentary (on and off) action once the 12 volts applied and then that same momentary action once the 12 volts is removed ? The 12 volts is on and off as my stereo is turned on and off, the momentary switching action would turn on a PC from hibernation and then back to hibernation. Currently the PC is hard powered off and on which has disk damaging possibilities already experienced. :mad:
    Can I buy something like that or rig it up ?
  2. ob2s
    Mar 18, 2009
    I guess I could have a pair of relays in series
    one that is Normally open with a 1-2 sec delay upon coil de-energization
    and
    one that is Normally closed with a 1-2 sec delay upon coil energization
    are there relays like that ?
  3. KL7AJ
    Nov 4, 2008
    2,047
    295
    Yep...what we used to call a "dropout relay" in the broadcast biz
    eric
