Off the shelf charge contollers?
Discussion in 'General Electronics Chat' started by spinnaker, Nov 26, 2010.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,065
    1,176
    I am looking at adding a charge controller to my solar garden light timer project. I don't need much. My panel is probably only about 10W and the battery is only a 5AH SLA. Most of the below are probably overkill but if this all works out we may invest in a bigger panel and battery.
    I have looked at:
    The Sungaurd
    Which claims to be very efficient.
    The Sunforce
    Even their website does not have much data. But it can be bought at Radio Shack.
    This one
    No name or anything. No telling how efficient it is.
    Any thoughts? Or maybe recommendations on another charger?
  2. timrobbins
    Aug 29, 2009
    318
    16
    Have you checked if the battery can be ever overcharged with the PV panel (worst-case charge current versus time)? You may need no controller at all except for a series diode.
    Ciao, Tim
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    Friend had the Sunforce, worked fine up until he was doing something and hooked the power up backwards. That model didn't have polarity protection in it.
  4. spinnaker
    Oct 29, 2009
    5,065
    1,176
    How can I test that?
  5. nickelflipper
    Jun 2, 2010
    280
    35
    I have the Morningstar Sunsaver 10A controller in my pickup slide-in camper, it has worked well for the last five years. Have used 60W to 135W of panel power, into a 100ah flood lead acid, and lately an AGM type battery.
    To my knowledge, the Sunsaver (like the Sunguard?) is an analog pwm type of controller with temperature compensation. It has a voltage limit, but not real sure as to what amount of hysteresis is built in.
