off Relay after 3 second Timer
Discussion in 'The Projects Forum' started by aghaarash, Oct 13, 2011.
  1. aghaarash
    Oct 11, 2011
    Hi guys. I want a circuit for relay which can turn off the relay after 3 second and it doesn`t turn off the relay if we reset the circuit or what ever to fresh this 3 second. if no action take place in 3 second then it turns off the relay.
    I really appreciate if some help me in this situation.
    Regards
    Arash
  2. #12
    Nov 30, 2010
    16,665
    7,313
    Power must be off for 3 seconds before the relay turns off, Right? Relay "on" persist? Which relay? Volts, current, ohms of coil?
    aghaarash likes this.
  3. maxthestork
    Oct 13, 2011
    13
    I think I can see a solution for your system using a 555 timer for the timing funcion and a latching relay like the Omron G6HK-2-DC5.
    You would set the relay when you turn on the power with a one shot action like a push button or a one shot timer function (again from a 555).
    A separate timing circuit from a 555 would handle the reset after 3 seconds. There is a section in the datasheet that describes a sequential timer on page 15 of the datasheet.
    cheers
    Peter
  4. aghaarash
    Oct 11, 2011
    dear peter
    I need a circuit that start counting for 3 sec and if there is no action in 3 sec it turn off the relay but if any action take place in this time a timer restart and count again. but I dont think 555 can do this. if you think I am wrong please let me know.
    Regards
    Arash
  5. aghaarash
    Oct 11, 2011
    I explain my situation again. it doesnt matter what is relay just a timer
  6. KMoffett
    Dec 19, 2007
    2,584
    234
    I think you need a "retriggerable monostable" flip-flop. What's "any action take place"?...a voltage change?...a switch closure?...??? Whether or not the circuit can directly drive a relay depends on the relay you are using. What voltage do you intend to use to power this circuit/relay?
    Ken
  7. aghaarash
    Oct 11, 2011
    It can works with 12Volt and any action means : reset.
    thanks
  8. tracecom
    Apr 16, 2010
    3,878
    1,396
    Sounds like an easy job for a microcontroller such as the PICAXE 08M2 (less than $3.00). The programming software is free, but one needs a programming cable; a serial cable can be made, but a USB cable is about $30.
    The AXE-021 is a project board that could be used; possibly the relay could be mounted on the board. http://www.phanderson.com/picaxe/
  9. KMoffett
    Dec 19, 2007
    2,584
    234
    12V, OK. Reset how?...by what? It might be easier if you would explain what you are trying to do, not just a 3 second timing circuit.
    Ken
  10. #12
    Nov 30, 2010
    16,665
    7,313
    This can be done very simply in analog IF you tell what the load is. The only way to keep a load powered for 3 seconds after the 12 volts is off, is to store enough energy to power the load for 3 seconds.
    What load?
    You don't say.
  11. VoodooMojo
    Nov 28, 2009
    503
    53
    dare it be as simple as this or am I misreading the OP's request?
    or perhaps we are to sense a load applied or removed from an external circuit?
    and how exact does the 3 seconds have to be?
