Hi Guys,
I have been doing my nut over an odd signal I'm getting on a new board I've designed. Basically the design is (supposed to be) an improvement of an existing design. Part of the design is communication with another PIC chip across an RJ-45/Cat-5 cable. The communication is working fine on the new design, except for on one channel. I'm getting these spikes in the signal that are causing errors in comm. I can't figure out where they are coming from. I was hoping someone here had seen the phenomena before or could otherwise, through deep magic, point me in the right direction.
See the 2 photos. Good signal and bad signal.
There are 4 data channels and one clock channel. On the old design, all data channels and the clock channel look like the good signal. On the new design, the clock and 3 of the 4 data channels look like the good signal and one of the data channels is the bad signal picture. I'm using everything the same when testing both the new design and the old design. The only difference is which board is plugged in. I've pretty well ruled out any possibility of anything else causing the problem other than the new board. It appears that the board matches in every respect, the old board. Yet these pulses appear.
I'm basically clutching at straws here. Can anyone tell me anything about that bad signal and hazard a guess as to where to find the problem?
Good Signal:
Bad Signal
Good Signal:
Bad Signal
