I have an odd questions about the level of knowledge/skill a person would need to solve a particular problem. I have the problem, and a possible solution. I'm wondering what level of knowledge is sufficient to solve the problem. In particular, it would be extremely helpful to identify a particular course or textbook in which the solution to this problem would be addressed (e.g., in a homework problem). Any help would be greatly appreciated.
The problem is as follows. You are working on a wireless communications system, System A. Your system is allowed to transmit on spectrum "A". Another system, System B, has been allocated spectrum "B". However, you may transmit on both A and B as long as you do not interfere with System B. Accordingly, you need to design a circuit that will allow you to transmit on A and B when you are not proximate to System B, and only transmit on spectrum A when you are proximate to System B.
The solution I have been given is to use a band-pass filter that allows A and B, and a band-pass filter that allows only A. Each of these will be connected to a switch and the switch will be connected to an amplifier and a transmitter. (figure attached)
What level of knowledge would you need to solve this problem? (e.g., 2 years of a B.S. degree in EE, B.S. degree in EE, etc.) Is there a particular course in which this would appear as a homework/test problem? Is there a particular textbook you can identify? Any help would be greatly appreciated.
Thanks,
Thanks,
