I'm testing a 50/12μF start/run capacitor out of an AC unit and got, what are to me, odd results.
I tested it with a VOM, qualitatively looking at the rate of change in voltage and resistance. The VOM works at 0.5V. The voltage had the expected slow drop for both capacitors. The resistance went to ∞ immediately.
I then redid the test with a 9V battery and got the same results, but in the 0.5-9V range.
Finally, I redid the test with just the VOM and observed a gradual increase in resistance.
I do not know what is going on. Could this be a temerature issue? I did the test in a garage at ~50°F. Did the 9V version of the test warm up the capacitor enough for it to function in the 0-0.5V range? I know this test is usually done on a hot summer day when the AC is broken.
