Octave down pedal
Discussion in 'General Electronics Chat' started by MDK, May 12, 2008.
  1. MDK
    Feb 1, 2008
    22
    Does any body now how to make an extremely simple octave pedal?
  2. MDK
    Feb 1, 2008
    22
    More specifically 1 octave down.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, just the PEDAL is simple. A normally open single-pole single-throw switch, connected to a 1/4" phono jack would do.
    The trick is to re-map your instrument so that the sustain pedal input causes a 1-octave shift. This could take some fiddling around, and it may not even be possible unless you have a professional instrument.
    You might be able to send the octave change command using a MIDI SYSEX, but that's not going to be simple, and would be instrument-dependent.
  4. nigelwright7557
    May 10, 2008
    488
    71
    I have seen these in electronics mags.
    Basically amplify the signal first until it is upto TTl levels then pass it through a flip flop to divide by 2.
    In the version I saw they allowed mixing of the original signal (amplified) with the new divided signal.
    If your really brave do the same thing with a PIC micro but double and half the input frequency to get a nice fat sound.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, I'll plead ignorance then :)
    Here's a link to a discussion elsewhere that looks rather promising:
    http://electro-music.com/forum/viewtopic.php?t=15019
    It links to this page:
    http://www.robthefiddler.com/electronics-audio-diy/circuit-experiments/subripplerv1/
    experiments with using a CMOS 4060 IC for a frequency divider.
    I can't imagine getting any kind of fidelity through such a circuit, but you could wind up with interesting effects.
    I received quite a few hits with this Google search:
    http://www.google.com/search?q=octave+pedal+schematic
    Some quite useful, many not.
    This page has a good generalized description of a couple of different types of octavers:
    http://www.bassplayer.com/story.aspx?content_id=24674
    along with reviews of several commercial brands.
    The A-D-A type might be programmed into a speedy PIC or other microcontroller. In this case, the hardware would be the easy part; the signal processing could get a bit dicey.
