ociloscope ground clip
Discussion in 'General Electronics Chat' started by gjo, Oct 29, 2013.
  1. gjo
    May 22, 2013
    28
    When using an isolation transformer, where do you connect ground clip of oscilloscope and why?
  2. #12
    Nov 30, 2010
    16,705
    7,354
    You connect the scope ground anywhere on the circuits on the output side of the isolation transformer because that is the safe side.
  3. gjo
    May 22, 2013
    28
    Is there a preference, because In the circuit diagram of a light dimmer they have it right after transformer secondary terminal
  4. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Of course it depends on what you are trying to display, but the initial reference would be the power -ve (common) of the circuit you are working on.
    If using AC from a isolated secondary, there is often a circuit common which would be observed intuitively.
    Max.
  5. #12
    Nov 30, 2010
    16,705
    7,354
    The preference is where you prefer it to be in order to measure what you want to measure. You have to look at the circuit, decide what you want to measure, and connect the oscilloscope in a way that measures the voltage on that place or part.
  6. GopherT
    Nov 23, 2012
    6,325
    4,051
    I think the op is confusing earth ground with circuit common.
  7. #12
    Nov 30, 2010
    16,705
    7,354
    This wouldn't be the first person to make that mistake tonight.
