Obtaining capacitor value for ripple voltage
frisbee4all
Joined Feb 22, 2009
13
Im trying to solve this problem:
Given a bridge rectifier circuit with a filter capacitor C placed across the load resistor R, for the case in which the transformer secondary delivers a sinusoid of 12 V (rms) having a 60-Hz frequency, and assuming V_DO = .8V and a load resistance R = 100Ω. Find the value that results in a ripple voltage no larger than 1 V peak to peak. I am using the equation C = V_p / (2*f*V_r*)R, where f is the frequency, and V_r is the ripple voltage. I am getting an answer that is off from the 1283 μF that the book is giving me. Also, the next step of the problem says to find the dc voltage at the output. I am assuming this would be the same as the peak-peak voltage if we assume that CR is much greater than T (the period). I don't fully understand how the book obtains dc values for its output, the only thing I can think of is that after the rectifier circuit and capacitor the signal is now consider a DC signal thust the output voltage across the load resistor is the DC voltage output. Is this about right? Thanks!!
ecb123
Joined Mar 6, 2008
7
frisbee4all:
The peak AC voltage out of the transformer is:
12.0*(2^0.5)=16.970 Volts Peak AC.
This passes through the rectifier converting it to a full-wave DC pulse voltage seen at the cap and load is:
Minus 2 diode forward voltage drops, 0.8*2=1.6 Volts DC:
16.970-1.6=15.370 Volts peak DC
We are given the load resistance of 100 ohms, so can calculate the needed load current that the cap must supply b/t pulses.
I(load)=15.370/100=0.1537 amps or 0.154 amps
The cap must supply for ideally (1/60 Hz)/2 =8.33 mSec, the ripple voltage is given:
C=I(dt/dv)=0.154(8.33 mSec/1 Vpp)=1283 uF
The DC output is ideally the average voltage over time of the observed waveform:
15.370-(1 Vpp/2) = 14.87 Volts DC
Note: I used the term "ideally" since the text assumes a linear ripple-when in fact there is also a small non-linear value due to the sine curve. Though the difference is insignificant suffice to know if you were asked to find the true value of DC voltage the text answers would be concidered close approximations.
