obsolete power transistor
Discussion in 'Electronics Resources' started by leonard, Jul 16, 2009.
  1. leonard
    Nov 29, 2005
    14
    dear all,
    i am looking for D7ST451010, a disc power transistor. Powerex, the manufacturer of this transistor said that is an obsolete device with no replacement. i am looking for some one or shop or store with old stock. please send the quotation to my e-mail <snip>
    thank you
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    It will be hard to find a replacement for a 3000 Watt transistor.
    I did find a copy of the datasheet.
    You could try a request at partminer.
    Greetings,
    Bertus
  3. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    If you can modify some of the part parameters you may find something at
    http://www.solitrondevices.com
    I don't see anything that matches that transistors power handling capability but they do have parts that can get close on either voltage or current, just not simultaneously. It might be worth a call to them and see if they have any recommendations...
  4. millwood
    Guest
    a 3kw transistor? that's the mother of all transistors, :).
    well, depending on how it is used, it can be replaced with others, like SCRs, or IGBTs, or even some lowly mosfets. sounds like it is for switching application and bjts aren't that efficient for switching applications so a lesser mosfet may fit the bill.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Hockey puck transistors are all goners. People use IGBT's instead.
  6. millwood
    Guest
    out of curiosity, i checked digikey for a high amperage mosfet. they have one from microsemi, rated for 860amp and 2.5kw! all for cool $200 a piece.
    I am sure you can make that work.
  7. leonard
    Nov 29, 2005
    14
    dear Millwood,
    i think i have find it at americanmicrosemi.com, it is D7ST451510KS. I am waiting the quotation from them now. Thanks for the reply.
  8. leonard
    Nov 29, 2005
    14
    dear Bertus,
    partminer don't have it. thanks for the pdf data sheets. i have been offered by americanmicrosemi.com D7ST451510. thanks for the reply.
  9. leonard
    Nov 29, 2005
    14
    hello StayatHomeElectronics,
    thanks for url information and advices.
  10. leonard
    Nov 29, 2005
    14
    hello beenthere,
    you right.
