observing polarity while installing capacitors
Discussion in 'General Electronics Chat' started by zzz, Dec 11, 2005.
  1. zzz
    Dec 1, 2004
    6
    Basic question. when installing electrolytic caps. {example..470 uf..} you are
    supposed to observe polarity. Does this mean ALWAYS put the neg.side directly to the ground bar or does it mean just make sure the neg. side is on the out put side?
    When you put an LED in a simple circuit you put the flat side DOWN and connect it to
    ground like a T. Is this the way with E caps or can they go inline as long as the neg side is to the out put side. Picture it on a breadboard. Thanks. A picture link would be good also.
  2. JoeJester
    Apr 26, 2005
    3,390
    1,211
    zzz,
    View your application.
    In the attached circuit, C1 is connected to -Vo ... so the positive end would be connected to ground. C2 is connected to +Vo ... so the negative end would be connected to ground.
    You won't make that mistake too many times.
