O scope purchase
Discussion in 'General Electronics Chat' started by Bobstein, Apr 24, 2013.
  1. Bobstein
    Apr 24, 2013
    5
    I have the opportunity to purchase an o scope the owner says that it powers on and a dot moves across the screen. Does that indicate that the unit will work?
  2. nigelwright7557
    May 10, 2008
    488
    71
    No.
    I bought a second hand scope that the second channel read off the wrong voltage.
    You need to try all channels with a signal generator.
  3. Bobstein
    Apr 24, 2013
    5
    Thanx Nigel
  4. tindel
    Sep 16, 2012
    576
    196
    If a dot is moving across the screen, then that indicates that the horizontal amplifier is working at low frequencies. At high frequencies - the dot should look like a straight line.
    You can check if the vertical amplifier is working by placing your finger on the probe tip and looking for a messy sine wave at about 16.6ms (60Hz).
    You can't really check calibration unless you have a waveform generator that's calibrated.
  5. Brownout
    Jan 10, 2012
    2,375
    998
    many scopes have a square wave generator available on the front panel for calibrating probes. Just connect a probe to it and you should see a square wave on the screen. You'll have to play with the controls a bit to see the wave.
