Tindel
What else do you use the external trigger input for? in your experience
Why on earth would you say something like this? The OP is just trying to learn something. If you don't feel like trying to explain it, then don't respond!I suggest you wait until you have more experience using an oscilloscope.
When you need external triggering you will realize it.
Think of the external trigger just like a third input into your scope that doesn't display on the scope. I just use it when I need to see a couple channels but don't really care for seeing the third signal because I've already looked at it.Tindel
So you convert 3 0-scopes into a logic analyzerI've also used it to trigger 3 scopes at the same time so that I can see 12 channels at once!
This has already been explained ad nauseum. Hook ext trigger of each scope to common trigger and each channel of the scope to each output. With 3 scopes of 2 channels would get 6 channels to monitor.So you convert 3 0-scopes into a logic analyzer
But what kind of signal can you use to sync up 3 scopes at the same time?
If you have are measuring time intervals or time duration , time periods
I have 3 scopes at works that are 2 channels only , but a lot of times i need it be like 10 channels to measure time periods of 10 different channels
How can I sync these 3 scopes up please? what kind of sync signal or signal do i need to use for the external trigger input?
What kind of use as a common trigger?Simply hook the ext trigger of each scope to a common trigger
How many times does it need to be explained? A clock signal is one example. Perhaps one of your outputs. Lots of things.. A trigger is what to triggers the sweep on your input channels.What kind of use as a common trigger?
This is what i don't know
Yes I understand thisA trigger is what to triggers the sweep on your input channels.
Why would you want to be looking for noise on a line frequency? its in microvolts why should that matter? it's not doing any harm rightyou are trying to see 20μV noise at 60Hz line frequency.
Because I said "noise at line frequency" not "noise on line frequency".Why would you want to be looking for noise on a line frequency? its in microvolts why should that matter? it's not doing any harm right
Either you have no businesses getting anywhere near a scope or this is your idea of a joke. I think the later.just trying to learn or understand what you're saying , cause i don't get it sorry
by Duane Benson
by Jake Hertz
by Jake Hertz
by Duane Benson
