o/p 4-bit comparator
Discussion in 'Homework Help' started by zulfi100, Mar 24, 2013.
  1. zulfi100
    Jun 7, 2012
    320
    Kindly guide me with the output of 2 2-bit comparators (i think its a 4-bit magnitude comparator) constructed by combing 2 xnor gates whose o/p is connected to a AND gate. When input 11 and 00 is supplied, i am getting 1 output though 11 and 00 are not same. Kindly guide me.
    Zulfi.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    Start with the boolean expression for your circuit. What is it?
  3. zulfi100
    Jun 7, 2012
    320
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    Now, what is another name for the XNOR gate? Specifically, it is HI when both inputs are ...?
    In the example you started with, the four bits that were applied, 11 and 00, how did those four bits map to the two 2-bit numbers being compared?
  5. zulfi100
    Jun 7, 2012
    320
    Ans. When inputs are same. Sorry I dont know the other name (wiki says enor or exnor).
    Sorry. I dont understand this mapping term. 1100 is mapped to 11 xnor 00.
    Kindly guide me.
    Zulfi.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    It is also known as the EQ, or EQUALITY, gate.
    Well, look at the slides that you linked. In particular, slide #6.
  7. zulfi100
    Jun 7, 2012
    320
    Okay. Thanks. I got it now. I should be:
    comparing 00 & 11
    so (0 xnor 1) and (0 xnor 1)= 0 (not same).
    Thanks for your time.
    Zulfi.
