How do you get the code from a NVRAM chip? because if I remove the NVRAM chip from the circuit board it will lose it's code
You use a universal programmer to burn code into NVRAM chips, but they will loose the code once you remove it from the universal programmer so how do you burn the code into NVRAM chips while it's soldered into the circuit board with a new battery installed
