NVRAM = non-volatile RAM. Usually have a backup battery/cap inside. Doesn't loose the data even when power is removed. Made from SRAM module.Originally posted by Surendar@Dec 29 2005, 02:45 PM
Ir RAM is Volatile then Could anyone explain what are NVRAM and SRAM and what are the differences between them.
Surendar
[post=12762]Quoted post[/post]
NVRAM can also be made of Electrically Eraseable or Flash Memory cells. They often have a serial SPI or similar interface. They typically have "read" times in the nanosecond/microsecond range while the "write" times might be in the milliseconds range. In this case you would consider them a read mostly/write occasionally type device.Originally posted by Dave@Dec 29 2005, 05:37 PM
Cache memory structures tend to be constructed from SRAM due to the faster operation compared to DRAM (SRAM tends to be somewhere between 8 and 16 times faster than DRAM). This is because the basic storage cell of SRAM is the flip-flop which is constructed from anywhere between 4 and 6 transistors, as opposed to DRAM which has a basic storage cell of a single transistor and capacitor. It is clear from this that although SRAM is faster, it doesn't have the density of DRAM and this typically makes it more expensive.
Dave
[post=12775]Quoted post[/post]
