What numbers are below 10?
Is -10 below 10?
Is -∞ below 10?
Is -10 below 10?
Is -∞ below 10?
Numbers below ten and two examples of numbers below ten were the OPs concern, until the OP clarified their request in post number five.Ironic that a question about writing style was misinterpreted by at least the first two people that read it.
If I was told that both examples are below 10 that would have been enough. I really did not need the writing example, although thanks for it as that was why this question came up.Numbers below ten and two examples of numbers below ten were the OPs concern, until the OP clarified their request in post number five.
I certainly wouldn't fault the first two responders when that ambiguity existed.
You were told that in post number two; which was questioned by another poster that the first two responders didn't clearly understand your inquiry. Your post number five introduced the grammer inquiry.If I was told that both examples are below 10 that would have been enough.
Loosewire you have hijacked a serious off-topic that may be useful to others. And your posting has nothing to do with the topic. You should refrain from such activity. If you need attention please start your own thread. No further comments on this will be made from my side on the topic, in this thread.Numbers below 10 should not be wearing bikinni's.
No Integcals,numbers below 10 and above 10
are Invisable. So when you see a 10 you put
a plus sign on It. Other wise what you see
Is not In the running,no number plus or minus.
Other words Your grand mother Is Infinity.
by Aaron Carman
by Jake Hertz
by Aaron Carman
