Number plate recognition
Discussion in 'Embedded Systems and Microcontrollers' started by skusku, Mar 2, 2013.
  1. skusku
    Thread Starter Active Member
    Aug 9, 2009
    70
    Hi guys, Im thinking ahead of my current capabilities.
    Just want to find out where I should start.
    I want to try and build a numberplate recognition system and send/log it to the computer. Obviously the software part on the PC I will something like python or C# using RS232 or so.
    Which micro controller will be best to use? Arduino maybe and interfacing it with a webcam or so. Otherwise i guess a rasberry pie can also do the job.
    Any suggestions from you guys?
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    You will need the power of r-pi.
  3. skusku
    Aug 9, 2009
    70
    What if one can do it using a pc for the processing?
  4. ErnieM
    Apr 24, 2011
    7,437
    1,626
    If you have a webcam taking pictures and a PC to evaluate the image, what is the micro controller for?
  5. skusku
    Aug 9, 2009
    70
    @ErnieM - There is no need to specifically have a microcontroller do the processing. If software only can do this and it would be easier then that is what I would go for. What would be the easiest option of doing this?
  6. John P
    Oct 14, 2008
    1,638
    225
    The easiest option has to be don't use a real-time camera at all. Just get your software working from stored images. You can probably find lots of them on the web, or go out and make a few with a digital camera.
    Easiest camera to set up is a USB-linked webcam, for sure.
  7. mcgyvr
    Oct 15, 2009
    4,791
    976
    opencv.. you're welcome
