Number of CMOS transistors required for...
Discussion in 'Homework Help' started by jegues, Sep 29, 2010.
  1. jegues
    Sep 13, 2010
    735
    43
    See first figure attached for problem statement.
    Second figure for my "attempt".
    I can't figure out how to calculate the correct number of transistors for a given gate.
    I figured well a NOT will require 1 CMOS transistor, and a NAND will require 2 CMOS transistors.
    So if I do a NAND followed by a NOT I'll get an AND.
    So a 2 input AND would be 3 transistors by this logic.
    Then a 4 input AND would be 6 transistors, but the answer says it's 10 transistors.
    Similarily, a NOR will require 2 CMOS transistors and if I follow this NOR by a NOT I'll get an OR.
    So a 2 input OR would be 3 transistors.
    Then a 3 input OR would be ? transistors.
    I need a better method for finding out how many CMOS transistors are required for each logic operation.
    Any ideas/suggestions/tips/hints?
    Thanks again!
  2. jegues
    Sep 13, 2010
    735
    43
    Bump, still can't figure this one out. Is there a systematic way of computing this?
  3. EngIntoHW
    Member
    Apr 24, 2010
    128
    How about drawing Karnaugh map for each function you wanna implmenet, find a minimized expression, of 2-input gates, and implement it that way.
  4. jegues
    Sep 13, 2010
    735
    43
    The function is already simplified. It's asking how many transistors are required to build that function.
    I don't know how many transistors are required for each logical operation.
  5. Ghar
    Mar 8, 2010
    655
    72
    I would say there's a mix up here in terminology... "A CMOS transistor" is super confusing since there's no such thing.
    CMOS is made up of NMOS and PMOS transistors.
    A NOT gate requires 2 transistors, 1 NMOS and 1 PMOS.
    A NAND gate requires 4, a 2 input AND requires 6.
    A 4 input NAND gate requires 8 transistors, add an inverter and you have 10 transistors.
  6. jegues
    Sep 13, 2010
    735
    43
    Okay so if we have 3, 3-input OR gates to make:
    A NOR gate requires 4 transistors. If I follows a NOR by a NOT I will get an OR. A NOT contains 2 transistors.
    Therefore a NOR followed by a NOT will give me a OR.
    4 + 2 = 6 transistors.
    But I have a 3-input OR not a 2-input.
    So I should have 4 + 2 + (4/2) = 8 transistors.
    8 times 3 will give me 24 transistors.
    Now, if we have 1, 2-input OR gate:
    1 2-input NOR requires 4 transistors. If I follow this by a NOT I will get a 2-input OR so,
    4 + 2 = 6 transistors for 2-input OR.
    Lastly, if we have 1, 4-input AND gate:
    A 2-input NAND gate requires 4 transistors. This followed by a NOT will give me,
    But I have a 4-input AND gate so,
    4 + 2 + 4 = 10 transistors.
    So that total number of transistors for this function will be,
    24 + 6 + 10 = 30 transistors.
    How does this look?
