Null output of op-amps to zero volts
Discussion in 'General Electronics Chat' started by DexterMccoy, Feb 27, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    When calibrating op amps outputs, you have to use a resistor decade box to null out the output of the op amp to zero volts
    Each op amp is output .100 to .900 millivolts
    This is when there is no input signal
    When nulling the output of op amps or a circuit stage so it's zero volts potential , is this biasing?
    Or what is it called or doing to the circuit when you null it out like this?
  2. DexterMccoy
    Feb 19, 2014
    429
    Mr Chips, I'm still having trouble with trying to make a new thread, thanks for doing this for me
    Title: low output servo amplifier causes damage?
    Can a low output voltage and low output current from a servo amplifier damage a gyro motor or servo motor? cause the motor to overheat or damage the bushing inside the motor? from having low current and low voltage applied to it?
  3. shteii01
    Feb 19, 2010
    3,516
    515
    Do you want zero volt input to produce zero volt output?
  4. DexterMccoy
    Feb 19, 2014
    429
    Yes
    Because if you don't , it will add millivolts of gain and it's a domino effect from each stage after being added and added of millivolts
  5. shteii01
    Feb 19, 2010
    3,516
    515
    Next question: What is the application?
  6. DexterMccoy
    Feb 19, 2014
    429
    Some of the Op amps are amplifiers
    Some of the Op amps are summing amplifiers
    The op amps do have a lot of feedback paths also , that feedback the output to other stages before
  7. shteii01
    Feb 19, 2010
    3,516
    515
    It is my understanding that if the device does not get enough voltage/current, the device simply does not perform. Which in turn mean that device does not work, and therefore does not break.
  8. DexterMccoy
    Feb 19, 2014
    429
    yes but if the current is not outputting enough, I think the gyro or servo motor gets damaged because the brushes or motor overheats because of the low current being applied to it right?
Thread Status:
