Voltmeter Impact on Measured Circuit
Chapter 8 - DC Metering Circuits
If the 24 volt battery were higher that the adjustable voltage source wouldn't that pull current through the null detector even it was the same voltage as the voltage across r2 given that the 24 volt battery positive terminal would pull electrons through the adjustable voltage source positive end?
