NTC thermistor needed?
Discussion in 'General Electronics Chat' started by Zeebit, Nov 11, 2013.
  1. Zeebit
    Nov 8, 2013
    72
    Is an NTC thermistor needed for a 100VA r-core transformer? I want to avoid blowing fuses and uneeded strain on the mains switch.
    Traffo will be used in a DIY CC/CV bench PS.
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    I guess that would depend on the rating of your mains supply/fuse/cable/switch ?
  3. ErnieM
    Apr 24, 2011
    7,443
    1,628
    There is little use in adding a thermistor to this transformer. You do not state where it would be. Most of the places I could imagine placing it would either lead to no function to pretty sparks & smoke (once).
  4. Zeebit
    Nov 8, 2013
    72
    I was thinking of adding it in series on the primary side (220V) to limit inrush current to avoid too much strain on the mains power cable, switch, fuse, etc.
    The traffo is used in a bench PS like I said above. Will it be fine to ditch the thermistor?
  5. Alec_t
    Sep 17, 2013
    5,980
    1,138
    I'd just use a 2A fuse in series with the primary. Your circuit should have a fuse anyway.
  6. #12
    Nov 30, 2010
    16,705
    7,358
  7. Zeebit
    Nov 8, 2013
    72
    Thanks everyone. I will just use a fuse instead. If I'm not mistaken r-core traffos are not as bad as toroids when it comes to inrush current.
