NTC Thermistor 10KΩ in parallel with 10kΩ Resistor.
Discussion in 'The Projects Forum' started by asif45, Apr 26, 2016.
  1. asif45
    Nov 12, 2015
    15
    Hi
    I have a 3.6 V, 4400 mAh battery with 10KΩ Negative Temperature Coefficient” NTC ( "Negative Temperature Coefficient” ) thermistors. (image attached). The blue wire is from NTC thermistor and it is connected with the negative side of the battery (black wire). I want to put another 10K resistor in parallel with this thermistor to decrease the resistance. i tried to connect 10k resistor at the end of blue and red wire but not sure is this the correct way. (image 2) Can any1 please tell me how can i do this?
  2. Dodgydave
    Jun 22, 2012
    5,141
    767
    Put it across the thermistor in Parallel blue/black wires. note the overall resistance will be 5k, at 25C temperature, and will decrease with higher temperatures.
    asif45 likes this.
  3. asif45
    Nov 12, 2015
    15
    Thanks a lot Dave!!!
