ns21 please read
Discussion in 'The Projects Forum' started by Chris15, Dec 21, 2009.
  1. Chris15
    Thread Starter Active Member
    Apr 15, 2009
    252
    Hello i cant figure out a way to do what you said latch with one press then unlatch with another press. to send a shematic or a picture you could e-mail me <snip> i beleive what your saying can be done as i am half way there and i need this circuit by christmas
    Chris
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Here is a simple push-push alternate action circuit. Its output current is low so it should drive a transistor for more output currernt.
  3. Chris15
    Apr 15, 2009
    252
    What does this circuit do?
    And what are the two big triangles? how would i wire up one of these
    I need the output to power a 9V relay so im not sure how to do the transistor thing
    If you have read my previous posts i am using a doorbell to controll this circuit it is 'Relay basic help" but i can easily use the relay from the doorbell as a sub for the push button, Basically this is what i need
    A circuit that s powered by the same switch, so for example a relay connected to a circuit with a pushbutton (in my case a relay) so i press the button relay powered i can make it latch, press same button relay unlatches or it can be done another way i just want to power a light with the doorbell, its output is 3V DC and im sort of in a rush as it is for some christmas lights
    Chris
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You won't have time to get the parts before Christmas.
    Sorry.
