ns pulse detection
Discussion in 'General Electronics Chat' started by abad109, Mar 14, 2011.
  1. abad109
    Mar 14, 2011
    12
    I have a device that produces current pulses that are 5 ns wide and occur every 10Hz.
    Could you suggest an amplifier IC chip fast enough to detect such pulses?
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    What voltage pulse...5V? How detected...stretched pulse width?
    Ken
  3. abad109
    Mar 14, 2011
    12
    Thanks for your response.
    Its a current pulse, microamps to nanoamps range.
    I was thinking of a transimpedance amplifier with GHz bandwidth to do so.
  4. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Really every 10 Hz. One pulse per 10 waves?
  5. Kermit2
    Feb 5, 2010
    3,852
    967
    ... detect it,
    Sorry, I mis-read that you wanted to create the pulses? or need to detect the pulses?
    more info would help. How are you coupling the signal to your input? Coax, tranformer, opto coupled?
  6. abad109
    Mar 14, 2011
    12
    i want to detect ns wide pulses
    the signal from a photodiode, which produces the current pulses may be connected through a BNC coax to the amplifier
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Coax is a long capacitor. The length of the coax will have a marked effect of both pulse height and width. Your results would almost certainly be better with a buffer amp driving the coax.
    Have you ever looked at a TAOS light-to-voltage converter? - http://www.taosinc.com/
    abad109 likes this.
  8. abad109
    Mar 14, 2011
    12
    Thank you for suggesting alternative to coax.
    i certainly want to minimize RC delays.
  9. abad109
    Mar 14, 2011
    12
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Coax does not look capacitive if it is terminated in its characteristic impedance. However, it still won't carry a 5nS pulse very far without degradation in transition times.
    Also, microamps into 50 ohms, or 75 ohms, won't leave much voltage to work with.:(
    Any kind of voltage buffer will be problematic. For example, a one microamp 5ns pulse into any realistic capacitance will have a 1mV/nS slew rate.
    You might be able to use a transresistance amplifier, but that is probably not something a novice could handle, and it probably couldn't be designed on one side of a forum and debugged on the other.
    Sorry to be so negative, but this is not a simple problem.
  11. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Agreed, but the drive is coming from a photodiode -
    abad109 likes this.
  12. abad109
    Mar 14, 2011
    12
    Thanks anyway for your suggestions. I will try my best.
  13. ifixit
    Nov 20, 2008
    639
    110
    Hi abad109,
    I agree, you need to use a transimpedance amplifier with a bandwidth of at least 1GHz. Mount it within millimeters of the photodiode. From there you can buffer again if required to drive a coax transmission line (50Ω).
    Regards,
    Ifixit
    abad109 likes this.
  14. abad109
    Mar 14, 2011
    12
    thanks, i will build and see, if there is some improvement .:)
