nRF24le1e RF Module
Discussion in 'Wireless & RF Design' started by ozirock, Aug 2, 2014.
  1. ozirock
    Jan 13, 2011
    44
    I bought a couple of cheap nRF24le1e modules expecting it to be a similar plug and play idea to XBee which in retrospect wasn't a very intelligent assumption. I was expecting to be able to communicate via uart with these modules as the data sheet shows pin 5 and 6 are TX and RX respectively but no such luck.
    After doing a bit of googling, it appear these modules contain a nRF24l01 plus a microcontroller. My question is, does this mean I need to try communicating with them via SPI and if so what use are the UART pins?
    Thanks,
    Oisin
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Please show the phot and schematic for the nRF modules you purchased. The photo and schematic should be in the vendor's ad.
  3. ozirock
    Jan 13, 2011
    44
    There is no real schematic but they give a pinout diagram and I can see the pins of the chip go directly to these pins.
    I made mistake with the pin numbers in my earlier post, this has the 32 pin package so the pins are
    VDD
    VCC
    Prog
    Reset
    P0.0
    P0.1
    P0.2
    P0.3 - UART/TXD
    P0.4 - UART/RXD
    P0.5 - SSCK
    P0.6
    P0.7 - SMOSI
    P1.0 - SMISO
    P1.1 - SCSN
    P1.2
    P1.3
    P1.4 - MSCK
    P1.5 - MMOSI
    P1.6 - MMISO
    P1.7
    I was using an FTDI cable to try and send from one module to another using the UART pins but I couldn't get anything to send so I guess that's intended for something else other than RF communication.
    I don't know anything about SPI but I guess the pins after P0.5 are all related to that so I'm going to have to figure that out if I want to send anything with these modules.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    That's a standard nRF IC in a module.
    What made you think there is a microcontroller on there as well? You can clearly see there is only one chip (the nRF IC) and a few discretes.
    Interfacing to the nRF IC is the same as all the nRF examples all over the internet. :)
  6. ozirock
    Jan 13, 2011
    44
    Oh it was because I read somewhere they had put a nRF24l0 die along side some other mcu in one package to make the nRF24le hence the extra pins but maybe that was wrong. I'd taught the idea was that the MCU would allow you to communicate with the nRF24l0 via uart rather than spi. I know pretty foolish :)
    I'll get a chance tomorrow to try the spi like the nRF24l0, hopefully that will work without too much trouble.
  7. BrentM
    Member
    Oct 26, 2012
    43
    I have used these modules quite a bit. Generally, I interface them with external microcontrollers using SPI, depending on the microcontroller being used. If you would like some schematics or more information, PM me.
  8. MachineHum
    Member
    Nov 3, 2014
    70
    It's an SoC... uC in the same die with the radio module... I think... there looks to be a programming line on that gerber layout and a bunch of GPIO...
    I've used the radio module, but not this SoC... I'll have to do a little more reading on it when I get home.
    From ebay listing:
    NRF24LE1 wireless communication module
    NRF24LE1 = NRF24L01 + MCU ; smaller with MCU
    NORDIC latest nRF24LE1 =2.4GHz + Flash 51+ADC +DAC + I2C + PWM+UART+SPI
    From Nordic's Site:
    "The nRF24LE1 is a highly integrated ultra low power 2.4GHz RF System-on-Chip (SoC) for 2.4GHz ISM (Industrial, Scientific and Medical) band operation. It includes a 2.4GHz RF transceiver core, an 8-bit CPU, and embedded Flash memory. By offering a peak RX/TX current lower than 14mA, a sub-μA power down mode, advanced power management, and 1.9 to 3.6V supply range, the nRF24LE1 provides a true ultra low power solution that enables months to years of battery lifetime when running from regular coin cells or AA/AAA batteries. Finally, a rich set of on-chip analog and digital peripherals makes the nRF24LE1 a flexible, single chip solution for a wide range of applications including PC peripherals, game controllers, remote controls, sports/fitness/healthcare sensors, and toys."
