nRF2401 wireless transceiver range very low
Discussion in 'General Electronics Chat' started by CVMichael, Feb 24, 2012.
  1. CVMichael
    Thread Starter Senior Member
    Aug 3, 2007
    416
    17
    I have 2 nRF2401 wireless transceivers, 1 set for transmit, and the other for receive.
    I got them from here: http://www.robotshop.com/ca/spark-fun-transceiver-mirf-miniature.html
    Datasheet: http://www.robotshop.com/ca/PDF/nordic-nRF2401A-datasheet.pdf
    I have set the power to max (bits 8 & 9) as "11" (page 23 & 32).
    I got it to work fine, but the problem is that it is loosing packets like crazy!
    It starts to loose packets after 3-4 feet, and almost no packets go trough after like 10 feet (in line-of-sight).
    In the RobotShop website it says the range is 50 feet !!
    Am I doing something wrong??
  2. praondevou
    Jul 9, 2011
    2,936
    489
    They work on 2.4GHz, right? This frequency range is used for a lot of other stuff, BT, Wireless LAN, microwave ovens.
    Try to test them somewhere else, in an open field somewhere outside maybe.
    transmission/receiving ranges are typically specified for open field (without obstacles like walls etc)
  3. CVMichael
    Aug 3, 2007
    416
    17
    Yes, it's 2.4GHz...
    Today when I got home, I tried it again, and it went about 10 feet further than yesterday... maybe tomorrow it will go 10 feet more :D
    Either way, it's still much less than expected.
    I will try to change the programming to be able to change the channels, and auto detect each other.
