First off, I love this website. I'm just learning about electronics (I'm 37) and AAC has been an info packed source for me.
I did have a question regarding wiring up an NPN transistor. Most other info sources show a base-emitter circuit and a collector-emitter circuit, but on on here it shows a base-emitter and base-collector circuit. Is there a functional difference?
On a little breadboard I have 5V pos. going to the collector and out the emitter, then to a resistor and finally an LED to ground. (collector-emitter circuit?) Then I have a 1.5v battery pos to 10K resistor to base lead, then out emitter to battery ground. (base-emitter circuit?) My circuit works as a switch. No led with 5V on collector-emitter circuit, and led on when 1.5v battery is applied to base. But isn't this configuration fundamentally different than what is shown on AAC?
Thanks for any and all help!
Chris
Chris
