NPN transistor array IC
Discussion in 'General Electronics Chat' started by BReeves, May 13, 2016.
  1. BReeves
    Nov 24, 2012
    412
    64
    I thought this would be easy but Google wasn't much help.
    I need to drive 7 relays from a micro with 5 volt outputs (Teensy 2.0). I'm driving 4 now with discreet 2n3904 transistors but need a smaller foot print. Was thinking it would be pretty easy to find a through hole IC that consisted of several NPN transistors which would take up less board space than 7 2n3904 transistors and associated resistors.
    Looking for ideas from you guys on what I might use to drive the relays?
  2. shteii01
    Feb 19, 2010
    3,500
    511
    5 volt relays? 24 volt?
  3. HW-nut
    Member
    May 12, 2016
    47
    12
    Texas Istruments ULN2003 relay driver IC.
  4. BReeves
    Nov 24, 2012
    412
    64
    That was quick... 12 volt relays, the Uln2003 looks like the perfect solution.
    Thanks..
  5. ScottWang
    Aug 23, 2012
    4,925
    777
    For a uln2003 or uln2004, the output current whatever for each pin or total is 500 mA, but considering the package and power consumption, using the current less 1/3(500 mA) is better.
  6. BReeves
    Nov 24, 2012
    412
    64
    Just discovered I already have several ULN2803's in my collection. Looks to be the same basic configuration as the 2003. Not sure how I ended up with them but they will sure solve the problem.
    Only one relay, maybe two is ever active at any given time and then only for milliseconds. If I use 5 volt DIP relays the coil current is only 40ma, current draw shouldn't be an issue.
    Cool, sometimes things just work out...
