Hello All,
I think I am a little confused with the operation of a transistor. Here is my doubt.
In NPN transistors, is it true that current flows into emitter node from the collector node?
Also, in case of NPN transistor, the overall effect is two diodes with Anodes connected, when both tha diodes are in active state (saturation region), in which direction does the current flow?
Again, when transistor is in acive region, BE diode is forward biased and BC diode is reverse biased.
In this case, does current flow from base to Emitter?
If so, I am assuming that emitter is the source of current but it is actually sinking current?
As you can see, I am a lot confused. Can I get comments please ...
