NPN/PNP circuit
Discussion in 'Homework Help' started by mas928s4, Aug 14, 2014.
  1. mas928s4
    Aug 14, 2014
    5
    I have this transistor schematic that has me scratching my head. I was wondering if there is somebody out there that can explain it to me. I know the basics of how a PNP and NPN transistor works but this configuration to me looks like a glorified switch? Also is the circled "A" an ammeter? and shouldn't it be a motor?
    Thank you,
  2. shteii01
    Feb 19, 2010
    3,519
    515
    anhnha likes this.
  3. Jony130
    Feb 17, 2009
    3,995
    1,117
    This is really bad design circuit. PNP transistor will work in "Inverted/reversed" region.
    You should swap the emitter with collector.
    And "A" for Armature.
    anhnha likes this.
  4. mas928s4
    Aug 14, 2014
    5
    Thank you for the link shteii. In all my years in field service I never ran across this configuration. I appreciate your quick response to my question,
    Have a great day
  5. mas928s4
    Aug 14, 2014
    5
    Hi Jony130,
    The wikilink explained the theory behind the design (H Bridge) pretty well as far as reversing the polarity of a motor which fits well with robotics. I agree the design isn't the greatest but is all I have to work with at the moment.
  6. studiot
    Nov 9, 2007
    5,005
    515
    anhnha likes this.
  7. Jony130
    Feb 17, 2009
    3,995
    1,117
    Hey what can I say. Try goggle "reverse active region".
    And the "correct" diagram should look like this
    http://forum.allaboutcircuits.com/attachment.php?attachmentid=71746&stc=1&d=1408034727
    And here you have a idiot-proof h-bridge
    anhnha likes this.
  8. mas928s4
    Aug 14, 2014
    5
    I'm not being critical as a matter of fact I am most appreciative of everyones input on this. To me its all good and useful information.
  9. Jony130
    Feb 17, 2009
    3,995
    1,117
    Ok, no problem. Any more question about the circuit?
  10. mas928s4
    Aug 14, 2014
    5
    I don't think so I think everything good.
