I have a NPN Common emitter configuration circuit using KSP2222A transistor. The power supply is from a 3Volt battery source. Please see the attached image. The circuit lights up the LED when the phototransistor detects infrared light.
I observed that the LED is bright when the Infrared light source is closer to the detector and not so bright when the IR source is slightly far. I don't want this behavior. I want the LED to have constant brightness even when the IR beam strength goes weak.
How do I make the transistor work like a real ON/OFF switch (instead of merely amplifying the intensity of IR signal)? LED should be switched ON even if the phototransistor senses the weakest IR signal. LED should be completely OFF when phototransistor detects nothing.
