Novice - totally lost
Discussion in 'Homework Help' started by eentijdgebruiker, Sep 6, 2010.
  1. eentijdgebruiker
    Sep 6, 2010
    I just started a EE class and the teachers just threw up there without really explaining everything. Everyone's lost. I tried to Google, but couldn't find anything.
    I have a breadboard, and I have a schematic I need to wire, but I do not really understand how to wire the VCC and ground (symbols). From what I've been told, VCC goes to power source positive, ground to power source negative. Is that right?
    I'm sorry for the painfully stupid / obvious questions. Course textbooks come in two weeks and the teachers are overloaded.
  2. Ghar
    Mar 8, 2010
    655
    72
    Yes, Vcc is the plus of your supply (either a bench power supply or some batteries or something) and Ground goes to the minus of your supply.
    Every point in the schematic labeled ground connects together, similarly with Vcc.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    I recollect that there is an on-line Java breadboard simulator - which may be of use to the OP.
