Novice needs help with what should be a simple P channel mosfet project
Discussion in 'General Electronics Chat' started by woodworkerjb, Dec 22, 2015.
  1. woodworkerjb
    Mar 20, 2012
    7
    I thought this would be a simple project but it has left me scratching my head. I pulled all my hair out on the last project so scratching is all I have left. The project is as follows:
    I have a 12v winch for my trailer. I want to use a 2 channel remote control for activation. The motor uses the standard starter solenoid to energize the motor. My research indicates the solenoid will pull 4 amps. The solenoid gets it ground through the frame of the trailer. The remote is simple enough, you just apply +5v and ground once a channel button is pressed it sends 5 volts to the channel pin.
    Because the solenoid is permanently grounded I decided to go with a P channel (irf9540) mosfet so that I could switch the positive side to the solenoid vs negative. My true problem comes from the fact that I need to now pass a negative 5v to the fet to activate where the remote passes a 5 volt positive.
    I tried using an opamp to invert the +5v to -5v but failed at this idea as well.
    In sum: I have a remote control module that outputs +5volts to a channel pin. I am trying to use a p channel irf9540 mofset to switch the 12v 4amp motors solenoid on and off.
    Any ideas on my approach or a whole new approach would be appreciated.
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    Use a transistor to invert your 5V control signal to drive the P MOSFET. I'll attach a schematic shortly...
  3. dl324
    Mar 30, 2015
    3,377
    651
    You're confusing the fact that the gate voltage relative to the source needs to be negative to turn on the P MOSFET with needing a negative voltage WRT ground.
    When 5V is applied to R2, Q2 will "invert" it and ground the gate of the MOSFET to turn it on.
    You need to add a snubber diode to protect the MOSFET.
  4. crutschow
    Mar 14, 2008
    13,482
    3,369
    In case you don't know, the "snubber diode" , such as a 1N4001, goes from MOSFET drain terminal (cathode) to ground (anode).
  5. dl324
    Mar 30, 2015
    3,377
    651
    For completeness...
    Values for resistors not critical. If loading on 5V control is an issue, R2 can be larger. Diode can be anything you have on hand. Even a 1N4148 signal diode can take 2A for a μS. Just about any NPN transistor will do.
    EDIT: snubber must handle 4A peak current...
    woodworkerjb likes this.
  6. crutschow
    Mar 14, 2008
    13,482
    3,369
    The op stated the solenoid draws about 4A, so a 1A or larger diode, such as a 1N400x, should probably be used.
  7. dl324
    Mar 30, 2015
    3,377
    651
    Thanks, I missed that...
  8. woodworkerjb
    Mar 20, 2012
    7
    Dennis
    Thank you so much that was a great way to solve my problem. I have tried it and it works. What would you suggest I add to the circuit to ensure the MOSFET stops conducting after the +5 volt signal is removed?
  9. dl324
    Mar 30, 2015
    3,377
    651
    You're welcome. The 10K resistor should be sufficient. If for some reason it isn't, you can make it smaller.
