Notron Theorem
Discussion in 'Homework Help' started by Apolonio de Tyana, Jun 13, 2004.
  1. Apolonio de Tyana
    Jun 12, 2004
  2. Mjollnir
    Member
    Apr 22, 2004
    27
    left side
    VOC = voltage across the 4kohm resistor in parallel (which is in series in the 4kohm resistor next to the source) = 4 / (4+4) * 10 = 5V
    total current delivered by 10V source when short circuited = 10 / (4K + 4K||3K) = 1.75mA
    ISC = 4/(3+4) * 1.75mA = 1mA
    so RTH = 5kohm, ur norton equivalent for the lefthand side is a 1ma current source with a 5 kohm resistor in parallel..
    right hand side
    do the exact same thing, but with 2 sources u can use either superposition or node voltage analysis...
  3. Apolonio de Tyana
    Jun 12, 2004
    Please, would you try to explane me again? Why you have used "4 / (4+4) * 10"?
  4. Mjollnir
    Member
    Apr 22, 2004
    27
    when it's open circuit, no current flows tru the 3k resistor, hence the voltage across A and B is the same as the voltage across the 4K resistor in parallel..
    but the 4k resistors are in series with voltage source when open circuit, so just use voltage division...
