notch filter design
Discussion in 'Homework Help' started by cruzziluv, Jun 1, 2012.
  1. cruzziluv
    May 30, 2012
    9
    help on how to design a notch filter with band reject frequency of 20khz
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    How much attenuation at the bottom of the notch?
    How steep are the skirts?
    How much ripple is acceptable in the passband?
    Active or Passive?
    How much power do you need to handle?
    What is the purpose?
    cruzziluv likes this.
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. #12
    Nov 30, 2010
    16,705
    7,355
    10 character minimum.
  5. cruzziluv
    May 30, 2012
    9
    its a 20khz active notch filter design witha reasonable attunuation level compared to the passband frequency.
  6. cruzziluv
    May 30, 2012
    9
    could not register
  7. praondevou
    Jul 9, 2011
    2,936
    489
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I do not respond to email requests. I answer in the open forum.
    The help you seek can be obtained via a Google search for "Active Notch Filters". The first five hits have pretty much everything you need.
    You still have not articulated your requirements. Is that because you don't have any requirements laid out? I'm just asking.
  9. cruzziluv
    May 30, 2012
    9
    was not given any specification,all that was given was the 20khz to be rejected. its the first time am working on this, thats why i need help on it. the calculations of resistors and capacitors using the frequency given. want to use the fliege notch topology.
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    So follow one of the articles and show us what you get. In real life any manager who gave you such an assignment without requirements would be considered incompetent and a prime candidate for being sacked.
  11. cruzziluv
    May 30, 2012
    9
    would do just dat
  12. cruzziluv
    May 30, 2012
    9
    this is what i got after simulating
  13. cruzziluv
    May 30, 2012
    9
    morning all, i breadboarded and sent a 20khz signal through my circuit from the oscilloscope it looks as if the signal was not there(like thiny ripples) but after calculations found out that the output signal was 16.67khz. Is that ok?
  14. t_n_k
    Mar 6, 2009
    5,448
    783
    If the input was 20kHz the output should be at the same frequency albeit at significantly reduced magnitude. Looking at your earlier post with your proposed circuit design - it does not appear to comply with the arrangement shown here
    http://earmark.net/gesr/opamp/notch.htm
    for instance.
    I would also suggest choosing a different op-amp and using bipolar supply for the op-amps. The amplifier bandwidth is quite critical to the outcome with respect to notch depth.
  15. crutschow
    Mar 14, 2008
    13,508
    3,385
    You cannot operate a 741 op amp from a single supply without biasing the inputs at 1/2 the supply voltage. Even then it's unlikely to operate properly with only 6V.
    If you want to operate from a single supply it would be best to use an op amp designed for single supply operation such as the rail-to-rail types. But even then you need to bias the input at 1/2 the supply voltage for AC signal input.
  16. cruzziluv
    May 30, 2012
    9
    thanks alot sir. trying to understand the function of various component in the fliege notch topology. any book or link to help me in understanding the role they play
  17. Audioguru
    Dec 20, 2007
    9,411
    896
    A 741 opamp is 44 years old, works poorly or does not work with a supply below 10V and operates poorly above 9kHz.
    You need an opamp that works well at 100kHz or higher.
    You need to learn about how to bias the input of an opamp that has a single-polarity supply since you have the input at 0V where the input does not work.
