Hey,
I am providing a 230v ac supply to the attached circuit which gets rectified and the output that I get from the zener diode is a constant 12v dc supply.
The requirement is that there should be just 1 negative trigger pulse that should be applied when the power supply is switched on and the output of the IC555 timer should be there for 500ms. I'm somehow not getting an output which specifies the above 2 criteria's. The output that I get is a positive trigger pulse and the output which remains low till infinity time..
Please help..
Please help..
