not gate
Discussion in 'The Projects Forum' started by sai150, Jan 25, 2015.
  1. sai150
    Jan 25, 2015
    i need a not gate circuit can anyone help me?
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  3. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    A normally closed switch or push button, simple!
    Max.
  4. Reloadron
    Jan 15, 2015
    1,038
    267
    Might help if you shared what you need it for. Small detail, like what are you trying to do? You have provided absolutely no information?
    Ron
  5. sai150
    Jan 25, 2015
    actually i'm working on a project
    i want a not gate circuit to invert output from a 555 timer
  6. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    2n7000, 2n2222.
    Max.
  7. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  8. Reloadron
    Jan 15, 2015
    1,038
    267
    If you just want to invert the output of a 555 timer I would just use a simple transistor as Max suggested. Just about any small switching transistor will work. Here is a simple example:
    Note Vout is inverted from Vin.
    Ron
  9. crutschow
    Mar 14, 2008
    13,469
    3,356
    If you want to use a logic gate, a CD4049 inverter would also work and requires only a single part.
  10. Alec_t
    Sep 17, 2013
    5,956
    1,131
    What are you driving with the 555 output? With a typical load drawing less than the rated 555 output current, instead of connecting the load between pin 3 and ground you can connect it between pin3 and the positive supply rail.
    GopherT likes this.
  11. GopherT
    Nov 23, 2012
    6,297
    4,019
    As Alec said above, connecting to v+ inverts your signal. See below...
  12. sai150
    Jan 25, 2015
    thanks a lot guys
