Not gate using transistor
Discussion in 'Homework Help' started by logearav, Aug 24, 2011.
  1. logearav
    Aug 19, 2011
    248
    Dear members ,
    Please see the enclosed attachment.
    This is NOT GATE implemented through NPN transistor.
    I framed the equation for the collector emitter side as follows
    Vs = IcRc + Vce
    where Vs is source voltage, Ic is collector current and Vce as the voltage drop across collector emitter.
    I dont understand the following concept
    When the input is 0, the transistor is in off state, so there wont be collector current so Vs = Vce. , the out put will be 1. Similarly when the input is 1 the transistor is saturation state so the output will be 0
    Please throw some light on these concepts and let me understand how NOT gate is implemented using NPN transistors
  2. Zazoo
    Member
    Jul 27, 2011
    114
    43
    When the input is 0 the transistor is in cutoff (like an open circuit). No current flows through Rc, so no voltage drop occurs across Rc and your equation reduces to Vs = Vce (since Ic = 0).
    When the input is 1 the transistor is in saturation (like a short circuit). Vc is at nearly the same potential as ground (≈ 0).
