Here's a project that I worked on for a little bit. I wanted to design a circuit that blinks a row of 20 or so LED's (third brake light for a car).
Legality (no local laws or regulations against this issue) and practicality (I want to build it, not go to the store and buy a box), here are the project requirements
Blink x number of times, then switch to constant ON
It would also be nice to have the ability for this to be wired "inline" - that is, have the module installed in such a fashion so I only need to clip one wire and insert the module "inline" to that one wire.
I have only 2 classes of EE experience in college, nothing complex, class 1 was basic intro (this is a resistor, this is a diode, etc...) and class 2 was some less-simple stuff (this is a RC network, this is an op amp, this is a transistor)
I was playing with a simple java based circuit simulator which provided pretty much all I needed and this was what I came up with:
It is based on a 555 timer, counter, some logic, and a MOSFET switching transistor. Nothing too complex.
I'm looking for critiques, comments, and ideas for improvement. This will be mounted on a PCB and put into a box; or, if I can get it small enough and get it working "inline", epoxied, jammed into a heatshrink tube, and spliced inline.
Thanks for looking!
Thanks for looking!
