Norton's theorem
Discussion in 'General Electronics Chat' started by KCHARROIS, Mar 27, 2014.
    Jun 29, 2012
    So there's a question in a book asking to solve a circuit using Norton's theorem and I've only been able to solve it using superposition. (Circuit attached)
    So to solve using superposition here's what I did, I opened the current source and calculated 12V across R1 and 8V across R2, simple series circuit. Next I shorted the voltage source and calculated -6V across both resistors, simple parallel circuit. Then adding and subtracting the values I get 18V across R1 and 2V across R2 and this makes sense.
    But how can I calculate using Norton's theorem, It may not be the best method but I'd like to learn.
    Edit: Forgot to mention that the 1mA source is actually an unknown resistor but has 1mA running through it.
  2. daviddeakin
    Aug 6, 2009
    You have a 20V source in series with R1. Convert that source into its Norton equivalent instead:
    You can now re-draw the circuit as two Norton sources in parallel:
    I4 in parallel with R2
    and a 0.1333mA source in parallel with R1.
    The total resistance becomes R1||R2 = 6k
    And the total combined current is -1mA + 1.333mA= 0.333mA
    Ohm does the rest.
    KCHARROIS likes this.
