nortonization and nodal analysis
Discussion in 'General Electronics Chat' started by PG1995, Jul 1, 2011.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
    Hi
    Please have a look on the following link:
    http://img836.imageshack.us/img836/1554/circuitmm.jpg
    1: I was trying to solve a circuit. I was successful except the part where I was trying to apply the nodal analysis (it's at the very end of the linked scan). Where am I going wrong? By nodal analysis I get Isc = 1/3 A which is wrong. Where did I go wrong?
    2: How would we proceed while applying nodal analysis if the 12V voltage source's polarities are reversed?
    It would be very nice of you if you could help me with the above queries. Thanks.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Your circuit is cut off at the top of the scan.
    hgmjr
  3. PG1995
    Apr 15, 2011
    753
    5
    Hi hgmjr
    Yes, you are correct; the circuit is cut off.
    But the cutoff part only contain a 8Ω resistor.
