Norton/Thevenin equivalencies
Discussion in 'General Electronics Chat' started by kawafis44, Apr 4, 2008.
  1. kawafis44
    Mar 13, 2008
    1) Find Norton and Thevenin equivalents.
    2) Use a series of Norton-Thevenin and series/parallel transformations to reduce a circuit shown into the single-loop circuit. Then, find current I. (Current I is between two nodes at the botom of (1) circuit!)
    I have got two exercises which I try to solve.
    Thanks for help in advance!
  2. veritas
    Feb 7, 2008
    167
    for problem 1)
    You seem to have almost all of the correct steps:
    step (2): you left out your output nodes, what is the resistance seen across it (it should be across the 2ohm resistor
    step (4): what is the voltage across the output?
    step (6): In this step, it appears you have changes the output port. Make sure it corresponds with the previous step.
    for problem 2:
    all of your steps appear to be correct. Now just short your open port.
    You can then combine the voltage sources and find the current.
  3. veritas
    Feb 7, 2008
    167
    I edited my answer because I was originally unclear on the prompt for question (2).
