Norton question
Discussion in 'Homework Help' started by gunmetol, Jan 29, 2015.
  1. gunmetol
    Jan 29, 2015
    7
    I have been struggling with this question (see attached) any help or guidance would be appreciated
    I have completed parts1,2,3 but i am stuck on part 4 as i am un sure how to go about this using Norton's i was wadering if any one could point me in the right direction on how to carry this out using Norton.
    oliver
  2. WBahn
    Mar 31, 2012
    18,093
    4,920
    What are you unsure about?
    Do you know how to find a Norton equivalent circuit treating the inductor as the load?
    You need to show YOUR best attempt so that we can at least see where you are trying to head and where you are going off the path.
  3. shteii01
    Feb 19, 2010
    3,518
    515
    I don't see a requirement to use Norton.
    Why not use Node Voltage or Mesh Current Methods to find the total current?
  4. WBahn
    Mar 31, 2012
    18,093
    4,920
    I'm assuming he has chosen to use Norton and, given that he is struggling with it, it's a good choice.
    I'd recommend he due it using Node and Mesh separately and also Thevenin. Sounds like he needs the practice (which we all did at one time).
